Baxi Bermuda Inset 2 50/4E Gas Fire and Back Boiler
22 May 2006
Hi can ay one tell me what type of flue i need for the Baxi Bermuda Inset 2 50/4E Gas Fire and Back Boiler, its second hand and a 2001 model, can i utilise my solid fuel fire flue?
Andy
I wouldn't dream of reusing any sort of old flue arrangement even if it were for the same type of boiler, which yours isn't.
You need someone qualified and knowledgeable to do this work.
under PArt L you cant fit it anyway
also no way you can use a flue liner that has been used for solid fuel, also the BS do say that if the flue liner is over five (I think) years
Need the flue lined with a flexible flue liner sealed top and bottom, but as said above you are never going to attempt to fit this yourself are you? and if not you will be lucky if you escape the new condensing boiler regs to allow a registered installer to fit it.
BS say 10 years for a flue liner cm ;)
