Baxi Bermuda Inset 2
14 Nov 2006
Staffordshire
We've just moved house and we have a back boiler behind the fire a Baxi Bermuda Inset 2 and a tank in the bathroom, the radiators when switched on are hot within a few minutes but the hot water tank gets hot after about 2 days from the coil in the tank. When you switch on hot water it turns the pump on the valve kicks in the pipes are hot but the boiler does not kick in downstairs only every 10 minutes or so but still no hot water.
The thermostat was set to 160 degrees Fahrenheit on the boiler when we moved in i have tried it at different temperatures it clicks the pump off at 100 i think it's a dodgy thermostat
any help greatfully recieved
boiler and pump are wired together, are you sure the hot water is pumped and not gravity?, are there any valves on the system?
