Baxi Bermuda Inset 3 50/6 back boiler fault code : 3 flashes
22 Oct 2014
Somerset
Hi
I can't get my back boiler to fire up. The fire works fine but the central heating won't play ball. The pilot had gone out. I tried to reset as explained in the manual by turning the thermostat dial to off (which gives an amber/green led, leaving 10 secs then turning on again. Initially, the pilot tried to light but was unsuccessful. After that I tried the reset many more times, but the led goes straight to red (lockout).The orange indicator LED is flashing three times.
According to the manual, this fault code is described as 'flame detection' and talks about a series of checks which include pilot sensing lead, probe, valve and PCB components.
Has anybody come across this before or can anybody shed any light on how to fix? Is it something I can do safely (reasonably handy DIYer).
To fix this common problem requires access to the boiler section by removing the fire front. It requires expert attention, as disconnection of gas parts is needed. Call someone in. This work and the mandatory safety checks afterwards is not for diyers.
Baxi made bombproof Back boilers boilers. Sadly yours has a weak point- electronics
Hi
Thanks for your reply. We will call someone in. After looking at the last service paperwork, there was a new PCB, gas valve, gas lead and thermostat fitted in May this year. Could any of these parts need replacing so soon? This would also beg the question about whether this boiler is worth spending any money on at all...not that we have a lot of choice at present as we need heating !
