I'm a DIYer, so please bare with me.
I have a Baxi Bermuda C5W (is C5W just the front?) back boiler, which is a gravity fed system.
I drained down the system to move and replace a couple radiators. When I drained it down, I didn't open all the bled valves (which I guess I should have?) and drained via a ground floor radiator in the hall. I carried out my replacements and went to refill.
I've had a small understanding / did a bit of research, so insured that I bled the radiators ground floor up, furtherest from boiler to closest etc.
Now while I got all the air out of the radiators once I turned on the system only the radiator closest to the boiler was getting hot. Turned off and bled the system again, bled and checked the pump (which is on the return pipework - I'm assuming from some forums I've found this is okay).
I tried to flush through from the two radiators downstairs that I installed drain cocks on.
Anyway, now when trying to fire up the heating the boiler fires up, sounds like a bag of nails and seems to stop working (although no lock out light).
Tried a few things I've read like closing the lockshield and TVR of working rads etc.
I'm trying to work out if this is an airlock or blockage and how I would narrow this down. I did contact a few plumbers in the area but as soon as I mention backboiler they say they can't work on them.
Any help would be great.
