We have a baxi bermuda that has been in the house for thirty years and has given up the ghost (needed a new valve that's no longer available). What seems very odd is that the system is gravity fed with a pumped radiator circuit but it has no separate feed and expansion cistern.
I'm guessing that the cold water cistern (for the hot water) is feeding the radiator circuit (the joint must be hidden somewhere as I can't see it in the loft or any accessible point) but the mystery of the open vent for the radiator circuit is even more bizarre:
The vent for the hot water comes directly from over the cold water cistern, right down to the top of the cylinder where it branches off. This is ofcourse how it should be, but I figure the radiiator circuit must also be joined to this at some point for venting the radiator circuit (as it doesn't seem to vent elsewhere and doesn't go to a separate feed and expansion cistern).
Can anyone tell me if they've come accross this before? It would go some way to explaing why the hot water is a rusty colour when you fill the bath to the top (from the immersion heater) - the two systems are combined. Was this the norm in the '70s?
Any Help would be appreciated.
P.s. I've bought an old replacement baxi bermuda 45/4m to get us through winter after which the house is going to be knocked around a fair bit and a whole new system will be commissioned. The only thing is, it's worrying me how this sytem ever functioned. The gravity feed for the cylinder isn't great, you'd assume that the cylinder should be directly above the boiler but it isn't - it's behind the boiler (about a foot higher) and the whole gravity circuit is about two feet from top(where it goes into the cylinder) to bottom (where it goes into the boiler). Obviously it did work but the replacement boiler has even less opportunity for gravity feeding (the distance from the inlet/outlet of the boiler is about 20cm less the the existing one.
p.p.s obviously I'd have the system checked before using it, but I don't want to waste my time connecting it if it's going to be pointless and/or dangerous.
