i have a Baxi WM 531 RS with an fault that causes the 3amp fuse to blow instantly when connected.
All the parts external to the boiler are fine and operating.
I need a systematic procedure to check want item from the boiler is causing the fuse to blow.
This issue started some time ago and intermittently blow the fuse after the boiler operated both hot water and central heating.
But now the boiler is not operating at all now and the the fuse is blown within .5 second.
Also once the repair procedure is identified a service engineer in the Brighton area is required, if anyone can make a suggestion.
Thanks.
David
Thanks.
David
