Baxi Boiler leaking Water
18 Apr 2006
Middlesbrough
My Baxi Solo 2 boiler started leaking water everywhere the other day.
i took the front cover and inner cover off and was confronted with some serious corosion all along the bottom row of plates on the heat exchanger. :(
In my head, i've written the boiler off as it's about 15 years old, but i'm wondering if this is really the case. Does anyone know if it's possible to replace the heat exchanger?? :confused:
also, in the past i've used Fernox Sludge remover to clear the system out, could this in any way have caused the corosion in my boiler?? If so, i dread to think what the rest of the system is like!!
On this boiler, its easy to replace the heat exchanger.
You just need to find a decent heating engineer that will take it on.
Did you use DS40? or the 'non corrosive' fernox sludge remover?
Stick with your boiler if atall possible.
I love these jobs, and you just need to find someone up there who thinks the same.
Not easy, when if more than a fan or PCB needs changing, most 'engineers' will recommend a boiler change as its more 'economic'
Regards
David
