I have a problem with a Baxi boiler Solo 2 40 RS - the pilot light stays on without any problem but if I get the boiler to fire up with heat or water on then it fires up and then after a minute or so goes off again, the pilot light stays on and the boiler will not fire up again unless I switch it of for a few minutes.
Last week I went through a pipe while fitting some flooring so I had to drain the heating system. It is all back on again and radiators all bled - the pump is OK as it was replaced recently due to previous being noisy.
Electrics seem OK - main fuse working.
System is about 12 years old - any suggestions ? - looking at previous forum entries seems to point towards the solenoid.
