just replaced gas valve on a 551 burmuda, burner and heat ex have been cleaned thoroughly. Pilot lights fine and burner fires up only to cut out after couple of mins (pilot stays lit). Any ideas?
because the previous one was not working and needed replacing, once it was swapped it began to work again but now there is the problem of the burner cutting out after min or two. customer does not want to upgrade system but would rather raplace any parts required to get this fossil up and running.
