Had no hot water due to warning light
Fault on Hot water sensor
A friend has narrowed it down to Central Heating Temperature Sensor
Did a bit of fault diagnosis
Un plugged this sensor put power back on and "Fault on Hot water sensor " disapeared however "Fault on Central Heating sensor" came on
Could someone explain why this would happen, why would the central heating sensor affect the hot water?
And by changing the central heating sensor would this cure the problem?
