Baxi combi 105 HE low pressue unable to top up
9 Jun 2013
Glamorgan
The pressure on my Baxi combi 105 HE suddenly dropped to zero and the water does not get hot. No sign of a leak. How do I top up the system?
One thing I noticed is that the far side chamber of the condensate drain is full of brown water but not sure if this is normal or not.
Any advice appreciated. Thanks
No, it's no hard at all. These have a built in filling loop underneath the boiler in the form of a braided hose. Each end of the hose is a tap which when turned, allows water into the system. Read the manufacturers instructions.
The condensate trap needs a clean and should be done when you get your boiler serviced.
