Hello everyone,
I've got an issue with my current thermostat Swtichmaster SM300 when on it buzzes like hell and setting the timer is just terrible.
I want to upgrade to a Salus RT510RF but I just wasn't too sure about all the wiring and wanted to double check.
By the thermostat controller there is the fused switch which controls the power to the boiler:
Below the boiler there is a box that has 2 wires coming in and 2 coming out to the boiler:
After taking off the boiler cover it seems that one cable is the mains supply and the other one is from the thermostat controller:
The boiler schematics are shown below:
And the thermostat I want to fit has the following:
My question is would I wire up the thermostat as shown in top diagram - 1 Low voltage or 2 as 230v switching? Also could I power the thermostat controller box from the same box that is powering the boiler?
Thank you
Thank you
