Baxi Combi 105e DHW NOT WORKING!!!
16 Jul 2007
Lancashire
HI, the problem is that when we run a hot tap the boiler fires up and everything seems ok and the lights indicating temp rise as normal, however when it gets to 50 degrees the flame goes out and only kicks back in when the water is almost stone cold!! thaen it stops at 50 again! the thermostat is turned right up! Please help!, i have had the temp sensor out and cleaned it but it hasnt helped!
Have a look at the post today. baxi 105e too hot . this is basically same as your prob
