Baxi Combi 105e -Hot water pressure
27 Aug 2013
Avon
I have a baxi 105e and the water pressure gauge is fine, showing 1.5, yet there is no pressure in the hot water taps. The water is hot but basically only trickles out, not enough to power the shower. The boiler ignition light shows yellow as the boiler 'fires up' and after about 5 secs it switches off. Even with this happening I have hot water in the taps, albeit trickling out.
Any ideas please, thanks
Lots of things going on there, some which will require the services of a gassafe qualified repair man. Best advice is to book a call and state the faults you have.
The pressure gauge is showing you the pressure within the CH circuit, not the HW pressure. As 45 states, you need to get a GS registered engineer out to diagnose your HW issue correctly
