baxi combi 105e not working
10 Sep 2009
Nottingham
Hi, I have a Baxi combi 105e which has suddenly stopped working. All power has ceased, no LED's are on. According to the servicing instructions it sounds liker it will be the PCB. Can you please let me know how easy this is to replace myself or should I get an engineer out?
Check fuse in spur 3 amp.
Also there is a 2 amp fuse in terminal strip in the boiler
Pump would be most likely suspect if fuse blown
many thanks for info. This sounds a little beyond my capabilities! guess its time to fork out some cash on an engineer.
