I have recently changed a leaking radiator valve due to low pressure now holding pressure when hot at 2bar. However, when the pre heat starts you can hear what appears to be air in the system when the pump runs, no leaks visible, but the bleed vale appears to worked although covered in lime scale. I have bleed the air from at the boiler several times but it keeps returning what is causing this fault is this a common problem?
Any advice or information would be welcomed.
Beau........
Beau........
