BAXI COMBI 105HE LEAKING PUMP
12 Apr 2008
Merseyside
My boiler pump has a slight leak due to a failed o ring seal.
Can I replace it with a Nitrile o ring of the same size, or will it have to be an original part.
Cheers.
Thank's for the reply.
I just thought it was a bit expensive to pay up to £4.50 each for an o ring if a readily available 28-22-3mm Nitrile rubber o ring is technically suitable.
Many Thanks.
If you have an O ring which fits & dont leak then result, dont forget to smear with silicone grease as this helps.
Also best to remove "manifold" out of inlet block and re-o-ring and silicone also.
