Hi Guys.
My Maxi Combi Boiler 105HE (which seems to have many problems reading this site) has decided its not going to work.
Every time its cold outside it won't light up, it goes into startup, fan runs, air pressure switch works and then goes into red flashing "flue error" light. I've had the fan pipework apart and checked nothing inside, the air pressure switch can be heard clicking on when the fan spins up but it doesn't fire up, its goes into (flue) error. I have this problem when its cold outside, if its warm it works fine.... HELP!!!
Should i rip it out and replace it with a non Baxi boiler?
British Gas want £210 to do a one time fix to it.
It was installed in 2003 and last serviced in 2007.
