Please could anyone advise what might be the cause of the issue I'm having with my combi boiler.
I had the heating on over night, and when I came to switch the heating off at the timer control, it wouldn't turn off.
So I turned it off at the Selector knob, and tried turning it on again. The pump worked fine, but it wasn't firing up. So I pressed the reset button on the timer unit and the pump spluttered a bit.
Where I am at now, the boiler will switch on and operate fine via the Selector knob and also the timer control apart from the fact that after the pump activates, the gas will fire up for literally 2 seconds then extinguish off again. After about 15 seconds, it will try again (the pump running all the time), gas fires up and extinguishes again - this is the cycle it does until it is manually switched off.
Any ideas please just so I know what kind of job is involved so it may match close to what a call out engineer will determine it could be.
cheers
cheers
