BAXI COMBI 80HE - PLEASE HELP GOING MAD!!!
28 Sep 2009
Berkshire
I have just tried to activate the central heating on our Baxi Combi 80HE and have the following indications from top to bottom on the neon indicator panel:
DHW neon (top-most with tap symbol next to it) GREEN CONTINUOUS
FLAME FAILURE neon: RED CONTINUOUS
FLAME neon: GREEN FLASHING
"ON" neon: (to left of CH temp knob) GREEN FLASHING
Basically the rads are not heating up at all. The thermostat clicks when passing a certain temperature but the but there is no iginition of the burner. However, when I turn on the taps the boiler ignites and I get hot water (have checked this by taking the housing off and observing flame viewing window)
I have also re-pressurised the system to ensure the pressure indicator on the boiler is in the green zone (it was reading low initially)
If I run through the neon fault indications on the inside of the boiler housing it indicates DHW flow switch but I fail to see how this would stop the rads from heating?
Can anyone who is in the know give some advice?
Thanks.
:D
would if its stuck :idea:
hw has priority ;)
So if the DHW flow switch is stuck, is there any way to unstick it or is it a straight replacement? What is its location on the boiler?
Thanks again.
Canadajim have you gave complete name of your boiler ..... IS IT 80HE plus
Thats why i am asking him if its a PLUS KEv going by lights .
Dont think they made a 80HE but the did make an 80HE instant
Was just thinking, if I didn't know any better, I'd would suspect Kev's been on the sauce. :LOL: :LOL: :LOL:
Hi All,
Yep, its a BAXI COMBI 80 HE PLUS - as placarded inside the lower door that drops down to allow access to the primary controls and neon indicator lights.
