Boiler is a Baxi combi 133HE+ and has been having a few problems.
The current problem is that when the thermostat calls for heat, the valve on that circuit opens and after a few minutes the main CH pump starts to run. The pump runs for almost exactly a minute without the boiler firing up and then the pump stops. After about 3 minutes this is repeated. So for CH it never actually fires up just runs the pump for one minute out of every 4.
Hot water works absolutely fine.
Before it started behaving like this it was seemingly randomly coming up with the LED code for dry fire every week or 2. Sometimes the reset button would bring it back and other times it needed to be turned off and on again. It never does this in the summer when only the hot water is used.
The engineer came to look at it for the dry fire issue but it didn't do it when he was there so he listed about half the parts in the boiler and said it could be any of them.
The pressure is fine - in the middle of the green segment.
Any ideas folks?
Thanks for your time to read!
Any ideas folks?
