Baxi Combi central heating losing pressure
1 Nov 2008
Oxfordshire
Since moving into my 2 storey flat 3 years ago, I have had to top up the water using the filling loop below the boiler as the pressure has been reducing to below 0.5 bar. (I top up to 1 bar when cold)
This summer I noticed a damp patch in the wall below a lot of the central heating pipes, so I investigated below the carpet. But the floorboards are some kind of thick chipboard slabs that will be a nitemare for me to get up to investigate the source of the leak.
I have noticed the damp patch is dry to the touch but not getting any bigger, so I assume its just a small drip which is soaking into the plaster.
I have since come across Fernox F4 Heating Leak Sealer Superconcentrate,
which is for sale in screwfix. Has anyone used this into the side of a radiator? Do you simply remove the valve screw at the top of the radiator and insert the fernox pipe and squeeeze. Do the radiators need to be cold?
Thanks in advance
turn off both valves undo the bleed screw have a bowl / cloth handy
screw tube into bleed screw hole pump in if it gets hard to pump open a valve slightly
if opened close valve catch water with bowl
replace screw open valves
check boiler pressure :) :)
