Hello. I've been doing lots of googling but can't seem to find a similar problem to mine with this boiler.
Firstly (this may or may not be connected), the HW was stick on (the fan was running for ever). The pin that operates the microswitch had got stuck with it out. I gently pushed it in and, after a bit of resistance, it popped back in and for now operates fine. So I'm guessing it got stuck, so probably needs taking apart for a clean-up and some silicone grease.
I can find a diaphragm kit that includes a brass gland and an alu washer. It looks like these are for the front, under the microswitch to me.
The problem I found while looking at all this is that there's a dripping from behind the diaphragm housing. It looks like it's from the join between this unit and the lump behind it, I think where the grub screws hold it in.
Is this something that can be fixed? I'm perfectly happy to take it apart, clean things up and change O rings and washers - if the parts are available.
If new parts are needed then would a new diaphragm housing include a new O ring to seal it into the lump behind?
Apologies for all my terminology no doubt being completely wrong - all help appreciated! Thanks.
