Orig problem was having to reduce DHW flow to retain hot water temp, gradually this became worse until no DHW at all. CH is all working fine.
So to be honest left it and used electric shower. However wifey not happy so need to fix it.
I am only a DIYer but noticed burner not firing up when hot tap opened. The differential valve was not operating the microswitch as the rods inside the valve were scaled up so I sorted this.
Now I have luke warm DHW although all the temp neons are lit, also the preheat function goes on forever and cannot light all the temp neons.
So as a test I swapped the leads over on the CH and DHW temp sensors with the following result.
CH rads cannot get fully hot, temp neons light up only to 50/60 degrees.
On the DHW side of things the tap water is still luke warm but the temp neons only light to 40/50 degrees. However the preheat function works normally lighting all the temp neons and provides a small amount of very hot DHW.
does this point to the DHW temp sensor being faulty.
thanks for any help / ideas
