First off I am no plumber and am not prepared to go back to the original installer as we have lost faith in him. The boiler is 3 years old and was recently serviced. Someone I trust has looked at the boiler recently but he could not be sure what the fault is and said its pretty much a trial and error exercise to change parts and see what fixes it. I'm just really trying to see if anyone out there has encountered this problem and if so, could you recommend where he should start.
The problem is basically that at any given random time the boiler will fail to ignite and display the E133 (gas supply fault) code. Incidentally the gas hob works ok, which I assume means the supply is ok. The problem is 100% intermittent, although it is becoming more common now, almost daily. There seems to be no logic to it, except that the boiler will almost certainly fail to ignite if we change the timer, or if we change from timed to constant. It resets ok everytime but it can take a number of resets (up to 5) before it ignites. It seems to start up ok, the fan comes on and the ignition clicks, it just fails to actually light the flame, although on some occasions it works first time. For info, we don't have a roomstat.
Any assitance welcome, Cheers.
