Hi I'm at my wits end with my heating my radiators heat up upstairs but stay cold downstairs I've bleed the radiators and flushed the system as I read its usually a blockage problem unfortunately I found no blockage. I then read it could be a pump problem and due to ruling the others out even tho the pump was spinning I decided to take it out to see if anything behind had broke or come away it was fine and is in full working condition is there any suggestions on anything else I can try to fix this problem ? thanks.
regards,
James
regards,
James
