Hi all,
I have a squealing boiler issue that seems different to the norm, well I can't find any similar posts regarding this!
When CH is on and hot water is demanded, by opening a tap (any HW tap), there is a loud squeal or whistle given off by the boiler. The squealing used to stop after a few seconds, but now continues until the hot water is no longer demanded.
This doesn't happen when CH is off.
It only happens when both Central Heating AND Hot Water are required at the same time.
Not wishing to lead you down a particular path, but I suspect the diverter valve - purely because it is the component that is responsible for switching from CH to DHW (and back) in this situation.
With the cover off the boiler, the noise *seems* to come from the diverter but it's very difficult to tell really.
I've taken the motor off the top of the diverter and pressed the pin up and down a few times - it seems free enough, but I've nothing to compare it with.
Does my reasoning seem sound to you experienced people?
Is a change of diverter required?
What else could it be?
I'd be grateful for any advice, please.
Many thanks,
Mike.
Many thanks,
Mike.
