Baxi Duo-Tec domestic water heat exchanger
20 Jun 2013
Suffolk
I had a problem with our combi boiler where the dom hot water would water hammer and also run cold, this I associated to be the domestic water heat exchanger having become either blocked or very dirty. I removed the heat exchanger without any big issue thanks to a posting from a similar thread.
Now I have cleaned as best I could and the system is back working, I have also ordered a replacement exchanger so that I can change this out for a known clean one. My question is this, The heat exchanger is identical either end so it will fit in either way, but there "was" a label which while cleaning was destroyed so I am not sure as if it is the correct way round or not.
On the ported side of the exchanger there are two indents to one side, would these be at the top or the bottom when fitted if this is only supposed to go one way round.
I hope you can understand what I am describing, when the new one arrives I want to make sure I fit it the correct way if there is a correct way that is.
Top Tip - There is a section called PLUMBING and CENTRAL HEATING.
The clue is in the name.
