Baxi Duo Tec HE 40 heating issue
18 Mar 2012
Middlesbrough
The problem I'm having is that occasionally, when the heating is switched on, the green 'radiator/heating' light comes on on the boiler, but not the amber 'flame' light.
While the boiler is on this state, radiators don't get warm.
If I turn the boiler off and back on, the heating kicks in as it should.
The controls until recently were the Boss Therm brtrf wireless thermostat, and this weekend I swapped it out for a Hive 2. Same problem occurred/occurs with both stats.
Here is a little vid if me showing the boiler with the problem, and how the heating starts working when I turn it off and on again.
Any ideas as to what the problem is likely to be?
That catches a lot of people out, myself included, most boilers when there is a demand for heating (radiator light) then the burner lights (flame light) but your boiler doesnt there is a delay before ignition , this is controlled by the boiler PCB you cant over ride it
Thanks for that. So I wonder if the PCB is at fault, because the boiler will stay in that state (radiator light on, but no flame light), and heating will not kick in even after 3/4 hours while the room thermostat is calling for heat.
As soon as I switch the boiler off and back on, both radiator light and flame light will come on and the boiler will fire up.
shouldnt take that long but have seen 10-15 mins if the power has been interrupted, shouldnt take that long though, the PCB is not cheap so I would suggest a Baxi fixed price repair and it will definately be sorted , rather thn keep buying different parts and hoping they sort your problem
