I have a baxi duo tec 28 HE which keeps dropping pressure and return E119 error code.
In the last month it's had to be topped up 3 times and I topped up again early this week to 2 bar and today the pressure has dropped to below 1 bar.
I've checked all the radiator valves for leaks but can't find any. No visible patches on the ceiling either. Downstairs the central heating pipes run under floor boards so can't really check unless I lift all the floors which I really don't want to do.
Is there any way or test that can be carried out to isolate where the leak is e.g on the boiler or on the system?
Basically I only want to go down lifting the floorboard if I can be sure the leak is on the system.
I've checked the pressure release pipe (the copper pipe outside) and no visible signs of water there either.
Any tips and advice would be appreciated.
