Hi havent had much to put right on these boilers have one that i have o go to and has no hot water but ch fine, customer says that the hot water neon doesnt come on when she runs the tap so im suspecting the hall effect sensor, any thoughts anybody?
Don't these also use a DHW thermistor to sense water flow as the temp drops?
I'm sure thats what my trainer said at Baxi, because I questioned him on whether this would be as useless as the Isar design when you get a dripping tap
yep i looked in the mi instructions , kind of guessed this anyway as the hot water indicator light doesnt come on when tap is run,themistor works as many other boilers sensing the resistance and altering burner pressure to control temp of water,ill sharp find out the morning let u know
