Baxi HE tripping mcb
15 Feb 2024
I have a baxi 28 he duotec that is tripping the electrics after an hour of the heating being on. No error code as the electric goes off. Thermistor possibly (values OK at room temperature.)
Can't see anything. If you give it a couple of hours you can reset the mcb and its fine again for an hour.
It's tripping the rcd at the board. Rcd resets if the boiler mcb is off.
divertor valve on left check its not leaking into the black motor attached
