had a roblem in the last 2 days with long time for hot/w to heat up goes cold then heats up and then its ok, hi i have just checked the air switch with a new one, and checked the thermo switch all,ok, what happening is turn the hot/w tap on and it will not spin the fan motor, then has flame failure flashing ,with the tap still on it resets it self and runs fine, it seems to be the first time u turn tap on it goes to flame failure, any ideas guys thanks
