baxi needs bleeding
25 Jul 2008
Somerset
HI Guys
Just replaced some radiators and they are bleeding fine, problem is once i start up the back boiler system the air bubbles sound very bad, but only on the pipes rising from the back boiler and sealed in the chimney breast.
I was advised to drain with a air release valve up at the tank as the system needs bleeding at a central point?
anyone know where this is, i can not find it by the tank.
but I do have a type of bleeder valve sticking out the side of the chimney breast in the lounge down by the skirting.
I don't want to attempt any turn on this as untill im sure what it holds as gas and water pipes are in the same place.
Cheers
HI
sometimes it takes few days for all noise to disappear.in the meantime try these
1.pump speed 3
2.bleed rads again
3.look for a air vent and bleed it
4.open big screw on the pump and release air
probably air traped in gravity circuit to hw cylinder just let it run with pump off and it will clear :LOL: or crack heatexchanger :cry:
