baxi potterton bermuda back boiler help needed
22 Mar 2006
London
can anybody help. im currently house sitting for a friend and have just changed the pump on his central heating system. i turned the boiler off first and fitted the pump correctly but when i tried to relight the boiler, the piezo ignition has packed up. is there any way of manually lighting this boiler? i have tried to put a fire lighter towards the back of the boiler where i can see the igniter, but am having no luck. the firefront is a baxi bermuda inset ts or bs. thanks in advance
Depends on the firefront, but if its the piezo unit thats gone you can often reach in and pull the ignition wire off and stick it on a new one without disturbing anything.
