baxi running constantly
27 Oct 2010
Gwent
Hi I got a problem with my Baxi combi 80he instant.Heating and water are both working but when I have it on just water if I open the hot water tap I get hot water but when I shut the tap off the boiler continues to run the hot water pipe from the boiler is hot and also the pump.
The only way I have found to stop this is to run the hot water tap again then shut it off then turn the preheat dial to about the 1 o'clock position and then back to off. Any help would be appreciated.
Thanks in advance bunaki.
