I have a Baxi Solo 15HE boiler that is just under 1 year old. When the heating is turned on from cold, after about 5 minutes the bolier begins to whistle for 2-3 minutes and will then go quiet again(still with the bolier running). This starting happening all of a sudden but doen't seem to be getting any worse - its just annoying when it does it every time the boiler is started.
The boiler doesn't whistle when the heating AND hot water is on - if you run both together for 5 mins and then turn off the hot water, the whistling noise will happen.
I've had the people who installed the bolier out to it and can't find a problem - so have contacted Baxi.
I just wondered if anyone had any ideas as to what it could be?
