Hi
I have a Baxi Solo 2 40PF boiler that is refusing to fire up.
About 3 weeks ago, the boiler started clicking on start up, the fan moved briefly (about half a turn) and then stopped. After inspecting the fan and the tube to the pressure sensor the problem was finally resolved (until tonight at least) by gently blowing on the PCB!
However, I came home tonight to find that the main fuse had blown. I replaced this, and the boiler on, fan on, pilot on lights all came on, the burner on light flickered, but the fan did not start and the boiler did not fire up.
I checked the pump and this seems to be working fine (it's making the same low humming noise as usual). I checked that there's 240V coming into the boiler. I replaced the fuse on the PCB, but this made no difference. I have checked the voltage to the fan from the PCB and i'm only getting 6mV - i'm assuming that this is far too low? I also noticed a small burn mark (about 5mm in diameter) on the bottom of the PCB near the connections to the fan.
I'm leaning towards replacing the PCB, but just want somebody better qualified than me to confirm this is the right thing to do.
Is there anything else I need to check first? How would I know if it's the fan that isn't working?
Thanks in advance.
Thanks in advance.
