baxi solo 2 50 pf
4 Oct 2005
Cheshire
Hi hope you can help me out , have just bled c/h system due to air lock refilled rads one at a time, expeld all the air in rads and pump but the problem is i car'nt get the rads to haet up and the boiler keeps over heating , now i asumed that i had to build up the presure in system so i took the cover of the boiler but could not find fill loop or presure gauge ?
is there one on the baxi solo 2 50 pf if not can some one point me in the right direction.
have done a search and this is what it said to fill the loop and presure gauge to 1.5 bar :confused: :confused: :confused:
cheers
mike
You need to find a bleed point on the pipework to get the air out.
there is a drain point on the pipework just above the boiler is this what you mean by bleed point and the rad system has filled up rads. 2 radshave now heated up but only upstairs
