Hi Guys
I have a baxi solo 2 50rs boiler installed in the garage with a frost stat. The boiler was working fine until this morning when the pilot light was off. For some reason when I press in the gas valve control and ignite the pilot, the pilot comes on first time round no problem, but when I release the gas valve control the pilot goes off.
I have tried several times and held down the control for several minutes but the pilot just goes off when released.
I have already fitted in a new thermocouple, overheat stat, pilot burner and injector, just for the winter so that there are no problems.
Could it be that I need a new gas valve?
This boiler does have somesort of safety cut-off device which operates when the boiler is to hot, could this be at fault, which again would mean a new gas valve.
Any advice would be sincerely appreciated.
