Hi all, got a Baxi Solo 2 40 PF boiler that’s acting up. Whenever there’s demand on the boiler, it will fire up, run for 10 or so minutes and then shut off despite the DHW/heating not being up to temp. It will the proceed to cycle between firing up and shutting off every couple of minutes.
Tried adjusting the pump flow rate and boiler temp gauge but with no luck.
It’s (semi) recently had the PCB and air sensor replaced on an unrelated issue and the engineer pointed out that the PCB must’ve undergone a revision between when the original and the new unit. Is this just a feature of the new PCB’s to cycle more frequently rather than running for a long time? The boiler fires up fine every time it does cycle but concerned about damage to the boiler in the medium term.
