- Joined
- 22 Jan 2004
- Messages
- 2
- Reaction score
- 0
- Country
Can anyone help? This boiler will not light unless you take off the front cover to get more air to the boiler or you hold a piece of cardboard over the flue for a few seconds which seems to build up pressure and forces the boiler to light.
Two separate heating engineers have looked at this boiler and the pressure switch has been changed, but this had no effect. It has been suggested that it could be the fan or a blocked flue or the circuit board not delivering voltage.
The electrode sparks with a good healthy spark every time and almost always there is a pilot light of varying strength that stays on for a few seconds but it does not light the boiler, unless you do either of the 2 things mentioned in the 1st paragraph, then it lights every time. The fan works and the boiler was last serviced only in the summer.
The boiler is 7 years old. Is is better just to replace it?
Any help or details of Baxi specialists in the West/North Yorkshire area who could look at the boiler would be very gratefully received
