baxi solo 2 pf fault
1 Jan 2011
Cheshire
hi all,
looked at the boiler and the pump was running but there was no fan light on and no power to it .Overheat stat and room stat ok.Instructions mentioned a check on the pilot solenoid which i tried but when i tried to do a coil resistance check it just read open circuit as did the main gas solenoid.(A more experienced engineer told me this is the case with some valves).
I cleaned the terminals on the pilot solenoid and checked the fan connections and when i turned the boiler back on it worked but when its alight on full there is a an electrical noise like arcing from the boiler.It didnt sound like ignition sparking and the boiler stayed alight and i couldnt place it as it happens too quickly.It may be a fan relay or a chattering solenoid but i could use some advice before i look at it till tommorow
As its a gas related fault I suggest that you ask in the Combustion Chamber part of this site where we can give you advice.
Tony
