Hi, hope someone can help me here.
My boiler has worked flawlessly for years but recently has stopped igniting the main burner. Everything works as normal, pump on, power on, fan on, igniter on (sparking) but no pilot light and hence no main burner
Occasionally the pilot will light up and the main burner will click and introduce gas but then it will all go out again.
The dodgy bit... If I lift the bottom of the combustion panel away from the boiler box the pilot lights immediately and the main burner comes on straight away, I leave it for ten seconds or so and then replace the panel and clip on the outer panel and everything works perfectly. It will even re-ignite properly for upto about an hour after being on.
Any ideas?
Any ideas?
