Hi
I'm not attempting to do any DIY but wanted to get some advice and opinions.
I had 2 brand new Baxi solo HE boilers installed in June 2010. one a 24 and an 18. I had 2 old baxi's removed and replaced with 2 new ones - no alteration in anything else.
No issues at all until April 2012 when one started to leak water and stopped working - as it was still under warranty the Heat team came and changed the heat exchanger which had broken. The chap said it was an unusual fault and didn't often happen.
December 2012 - the exact same thing happened to the other boiler - it was out of warranty so I coughed up the £300 emergency cover and a lovely man turned up, changed the heat exchanger and put me a new pump on too as mine was ' a bit noisy' so I felt all was well with my world and perhaps had just had a ' faulty batch' of exchangers supplied with the boilers.
This week Feb 2013 , the exact same fault occured again with the first boiler, ring them up and this time the chap didnt have a new exchanger on his van so I have to wait a week for them to come and mend it.
He said it was 'unheard of' for 2 heat exchangers to 'go' in 1 boiler in a year , never mind 3 in 2 boilers in a year.. and suggested it was the initial installation that was at fault and said that they wouldn't continue to replace them even though I have valid silver cover for both boilers.
I asked if he would check the installation and he refused saying he just mended boilers not looked at systems ...
Question:
Could this be true ? might the installation be causing this ?
If this was the case why did it see me through almost 2 winters and continuous hot water all year before any troubles started.
I'm starting to panic here that I wont be able to get them fixed under my cover as its an ongoing problem, but don't know what else to do to put it right permenently.
My installer is a full time heating installer /plumbing chap self employed and has been around for years so I'm assuming he's experienced. He obviously put it in how he thought best, so no point asking him and I dont want to pay out to someone else to check it when I cant see how it could be at fault and surely its up to Baxi to prove its an installation issue before I pay someone else.
Anyone any suggestions or comments ?
Many thanks in advance
Taflady
Question:
Taflady
