Baxi Solo 24HE Flow switch leaking
15 May 2012
Dorset
I have Baxi Solo 24HE which has developed a small weep from the flow switch.
Is this easy to change? I see there are 2 bolts holding it in place - do these screw into captive nuts/threads, or do I have to take the boiler front cover off to get at nuts on the inside?
As the switch itself seems to be working OK, is it possible (or sensible) to change just the o-rings on the inner and outer part? (It looks like the leak is from the inner part).
Or is this one of those bits best left to a boiler specialist? I am reasonably experienced with water pipework etc. on the outside of the boiler, and don't do work on gas.
