hi People
I have a problem with a Baxi solo 3 in that sometimes (getting more regular) it will not light. just the boiler on light is illuminated.
I have tried resetting boiler with the reset knob no luck. pump is running.
its the sequence which seems to be problem.
turn on only pump runs, no fan yet if I tap the aps with my finger the fan starts and it goes through the full sequence and lights/works perfectly.
has anybody had this problem? is it a sticky fan or could the aps be at fault
(stupid place to put aps at top of boiler as the sample tubes get heat affected over time)
thanks in anticipation
Bigun
Bigun
