I have a Baxi Solo 30 boiler that runs a pressurised heating and hot water system .
It 's about two years old a fires up fine and runs as expected except when switched off and cooled down it drips water from the bottom of the flue pipe that vents to the outside .
The leak is a constant drip that adds up to a least a washing up bowl full each night . The water drips from the join in the flue pipe on its first 90 deg elbow about 150mm above the boiler top .
My plumber says he will return and us silicon to seal the joint . Is he correct or is there another problem,perhaps the condensing draining system
Many Thanks
Many Thanks
