Baxi solo 50 /4 RS. Boiler would go out after a few minutes or a few seconds with a click. Got it to stay on for a couple of hours once but not again.
Called in the gas man who said it was ancient and we needed a new one which they could fit next Tuesday. Otherwise it would need a new gas valve. They could fit a new boiler inside 4 days but couldn't get the part for 10 days (!). So I got one for them in 48 hours. They fitted it and said it probably also needed the overheat thermostat. At least they only charged us cost for that.
Now 2 weeks later same problem happens again. After finding the baxi manual here https://www.dhsspares.co.uk/userfiles/Boiler_Manuals/BAX262.pdf I investigate further. Staring at the pilot light I can see it flickering, it is a windy day. Lighting the boiler I see the pilot light very unstable after the burner goes on full. Pilot light disappears - click - boiler goes out.
Moving the thermocouple connection I find the nut wiggles freely. If the Gas Safe man leaves it like that it can't need a gas tight connection (?!?). To cut a long story short I cleaned the pilot light injector and it now has a much stronger flame and the boiler is working again. So probably did not need the £250 work that was carried out.
Yes I will get it serviced/checked as quickly as possible (It is New Years Day). However my experience suggests that just being Gas Safe registered does not make an engineer competent or trustworthy.
