Hi guys, thanks for taking the time to look at this, I hope you can help. I have a Baxi Solo 70/4 and have just replaced the bearings in the fan, trouble is I can't remember which way round the motor outer section sould fit and this in tern will mean that the motor turns clockwise or anticlock wise depending which way round it goes, can anyone tell me which way the motor should turn when looking down on the outer casing from above. I have also noticed that when removing the rubber hoses from the pressure switch that there is virtually no pressure, certainly not enough to activate the switch which I can do by blowing down the tube which in turn ignites the boiler. The pipes are clear so what am I doing wrong. Thanks in anticipation of your answers, cheers, Sicobra
